I've got 99 International 9200 with 60 series Detroit that started and ran for a couple minutes this morning then died. Gauge showed 12 volts and it wouldn't turn over after that. Had one battery terminal with some corrosion so I cleaned that, put my hd jumper cables on it, let it charge for a bit and got it to start up again. The starter to took a second to engage, not a clicking like it was low on power, more of a hesitation. Anyway, truck ran for about 30 seconds, died again, and when I tried to start it the solenoid started shooting sparks, now I can't get it to turn over.
Bad starter? Its cold and rainy and the mechanic my fleet service sent over thinks something's wet and that's causing a short. Truck has been sitting all weekend so I don't know what would've got wet. Solenoid on top the starter was dry. I'm thinking starter / solenoid, its just odd that the truck died twice, which is something it usually doesn't do. They want me to let it sit and dry out, but with the weather it'll be a couple days before that happens.
