Diesel Rad Leaking Coolant From Oil cooler Fitting
uglytruk
IN A JUNKYARD, UNDER A TRUCK*N E Rust Belt
Yup, my California 4x4 Sub sprung a coolant leak when I plugged in the block heater. I guess it doesn't like the cold...
I tried to tighten it with a jumbo adj wrench, but I think I have ta remove the oil line bcause the nut is flimsy "play" steel...
Suggestions?
