I'm sure most of you have done this. You can still use the diesel harness correct? I found the hei and starter wires. But nothing in the cab works. No turn signals, wipers, headlights etc. I tested everything with a 12v source so the stuff works. I'm getting power into the fuse box too.
This truck has also been sitting for 9 years too. Soooo is this a diesel issue or is my wiring just jacked
85 k30 m1008
85 k30 m1008
