My K5 is starting to diesel again when I shut it off, and I'm tired of killing it in gear ... time to fix it.
Here's a list of stuff I know can cause dieseling and what to do about it; chime in with any others you know?
In this instance, timing should be dead on, and she diesels even after actual driving (as opposed to idling in my driveway.) There may be a heat issue, as I had to trim the fan shroud when I did the Doubler and I think the cooling has suffered since. I'll break out the infrared thermometer and double-check, as the factory gauge may be off. The gas is suspect, as it's oooold, so I'll get some fresh gas and/or dump some treatment goo into the tank.
Other than that, what else should I be looking at?
-- A
- Timing (check, reset.)
- Extended idling (goose the gas for a bit 'fore shutting it off.)
- Idle speed too high (set properly)
- Running too hot (fix cooling system)
- Crappy/old gas (fresh gas, treatment for what's in the tank)
- Carbon in the heads? (caused by heat, maybe, but how to check and what to do about it?)
-- A
