Okay, I'm stumped. Which doesn't take much, but I'm learning
Truck is my '74 K5, with a fairly new (20k maybe) GM crate 350, and a '75 hot-air style intake mainfold. Carb is a new-with-the-crate Edelbrock Q-jet replacement, 1903 I think.
Distributor is a reman; cap, rotor, wires, plugs are all new.
I've played with the timing until I'm blue in the t!ts and the damn thing still diesels when I turn it off. It's worse when the engine gets warm, i.e. it's really bad in hot weather.
After reading the diagnostic section in the factory service manual, I replaced the EGR valve, which seems to have helped. At the least, she starts much better.
However, she still diesels, and I hate turning her off in gear every time.
One oddity is that the points have been replaced with a Pertronix electronic ignition thing ... don't ask, not my idea. I could drop an HEI distributor on there, but I don't have one handy (well, except the one that's in my '77, and it's running so I'm loathe to mess with it
Should I go and play with the timing again, now that the EGR is presumably good ... or is there something else that causes dieseling?
-- A
)Should I go and play with the timing again, now that the EGR is presumably good ... or is there something else that causes dieseling?
-- A
--first small block I've had that did!)..but lowering the idle speed is what stopped the dieseling for me..Its possible something is getting hot enough in the combustion chamber to ignite the fuel and keep it running after the key is off--but that would lead to detonation or pinging under load too..if its not pinging,its probably not the cause...
