Diff breathers
stockk5
Cromwell, CT
a quick question on diff breathers, how should i extend them? im not sure if this is right but the way i would do it is just to put a regular fuel/clear line over the original metal fitting on the end of the hose and just clamp it w/ a hose clamp. Is this the correct way to do it? Does the metal end need to be the absolute end of the hose? Should i extend the transfer case breather as well. Is there one for the tranny, i have a 700r4 i couldnt find it when i was looking for it.
Yeah any regular hose will do, just take them up high. Do the t/case as well. Trans have a hole near the top on the side. You can't put a breather pipe on as there is nothing to attach it to. On my TH350 when I rebuilt it I tapped a thread in there so I could put a breather on.
Some trans' have a little plastic tube for the breather. It's usually near the top, on the passenger side, near the base of the b/h. What I've done is find some vacuum tube that fits tight over the plastic tube. Then fit the fuel hose over that. On the Project YJ (LS1/4L60E/D300) I used a double wrap of safety wire on the vacuum tube to hold it onto the plastic tube (too small for a hose clamp) and did the same thing again where the vacuum hose fit inside the fuel hose b/c there wasn't room for a hose clamp. I manifolded all four vent hoses together and used a K&N breather.
