mtnman210
Backstory: I fired up the truck the other day and it started smoking really bad. I thought maybe rings. So I tore it apart the last couple nights and found a broken Rocker. and really loose push rod. I went to slide the rod back in and it almost fell in the motor. So tonight I pulled the manifold and found the lifter sitting in the lifter valley.
Ok so it looks like just the rocker failed. I found the lifter under the manifold and it looks ok as well as it's slot. Apparently the rockers failing is a problem with this motor, so I'm looking at getting a nice set of aluminum ones instead of the stockers.
advice on which ones? these are the places I'm looking at since they're the only ones that have them.
http://www.cad500parts.com/catalog/page20.htm
I have no idea which stage I should get though. I'm guessing the Stage 3 setup?
Then I found this place out in Apple Valley(Local to me kind of). I was gonna give them a call tomorrow and see if they're in on Saturdays and go talk to them. These are the two styles they offer
http://www.mtscadparts.net/servlet/the-270/MTS-Roller-Tipped-Shaft/Detail
and
http://www.mtscadparts.net/servlet/the-269/MTS-Roller-Tipped-Shaft/Detail
My question here is what's the difference between the Adjustable Rockers and the Non-Adjustable set. besides 200 bucks?
and
