84_Chevy_K10
Banned
Re: Different carbs for more power on the Sand.... holley, barry grant, car
I disagree, my truck runs great with an 800 CFM Q-jet and I can't imagine a mech secondary carb that big having any place on a truck.
You guys are trying to re-engineer something that worked great on our trucks from the factory.
[/ QUOTE ] For high speed wheeling, I tend too agree on the Demon carb But for low speed with lots of off camber, I'd think a Q-jet would be best. Tim, what you fail too understand is that not everybody does the same type of wheeling that you do. What I'm doing, a Q-jet works great for me. But for the high speed things like Desert racing, I'd defently go with a Demon carb. I don't know much about sand running, but I assume it's a higher speed thing then crawling.
You don't know much about carburator operation either. Q-jets have a vacuum operated secondary door and flow 750 or 795 cfm from the factory. It's hard to be a properly tuned Q-jet for any type of wheelin', not just slow speed stuff.
To be honest with you, even a Q-jet is insufficient for the wheelin' that I do. That's why I'm putting EFI on my truck...but once again you have swayed the discussion to what I do with my truck, which you seem to think has an effect on everything I say on here. It doesn't.
The Demon might have bling factor but that's just about it. A mechanical secondary carb has almost no place on a truck at all, and definitely not on a 4x4 that is going to see any off road use.
Off camber? EFI
DD/mild off road Q-jet
Straight off the trailer and to the mud pit? Big, mech secondary carb
Off camber? EFI
