I'll start by linking the tech article.
http://coloradok5.com/doorhingepins.shtml
very nice and informative, can't wait to start since bushings are shot and need replacing.
I have a few questions. I've seen them touched on in previous threads but I want to start a short pre-build thread with some ideas and get feedback from ya'll.
1) Is grinding the splines off the pin necessary and why? Has anyone done a quick release pin without grinding/filing the splines? I'm sure it's easier to get the pin out, but I would think the splines are necessary to hold the pin better. The use of a tiny hammer (tappy tappy) to get them out wouldn't be a bother.
2) To anyone out there currently running this mod: Is there anything you would have done differently? Has the pins moved around any or loosened inside the bushings? It seems like the pin would have a little vertical slack, not having been pinched tight like the factory ones. Not sure if that's a bad thing, just thinking out loud. OOO and what are you supposed to do with these Dorman replacement pins anyway? Just put them in or are you supposed to pinch them somehow after installation?
3) After I cut the pins, I just tap them out in opposite directions right? Do the bushings go between each half of the hinge? Meaning, on the door half of the hinge, one bushing goes down ON TOP, and the other goes up ON THE BOTTOM. I guess I'll see regardless once I cut them out, I just like knowing everything before starting.
4) I've been looking at the connections in the door jam. I've come across a website with waterproof connectors.
http://www.suresealconnections.com/pdfs/sure-seal-series-entire-section-pgs11-26.pdf
On page 14, there are some connectors. I'm looking at the flanged one for the door and a regular one for the incoming wires. I think they are a twist lock style plug. Would really clean that area up and make unplugging super simple. Haven't called them yet for pricing or tools needed.
5) Has anyone tried using a bolt instead of the pin? I read that in an older thread. Talking about drilling out the bushings just a little and putting a bolt through with a nut at the end. Using a smooth shank through the bushing of course. Had anyone found a perfect size bolt, or a close one where drilling the bushings wont take too much material off?
whatcha think?
whatcha think?
