Different way to relocate spring perch on 14 bolt
Yukon Jack
Rose Hill, KS
Read in a mag that when swapping in a 14 bolt, some people make a plate that is welded to the existing spring perch and the tube rather than cutting the existing spring perch and moving it. Then the spring perch centerbolt hole is put in the correct location.
Can't see a strength problem if used correct sized steel, but wanted to hear opinions whether this is acceptable option. Here's a crude pic I drew from a pic of one of our member's axles (he did move his perch).
I saw that tidbit of advice from Willie, but have to wonder how you would get the U-bolt to fit over the axle on the side that still has the old perch in the way. /forums/images/graemlins/eek.gif I suppose that with enough grinding it would work, but with that much grinding and welding you might as well just move the perches! /forums/images/graemlins/cool.gif
That's a good point. I believe my 14 bolt that I will be swapping in has the spring perch that is solid so that would take a bunch of grinding to clear the ubolts.
i had to move my spring pearches it didn't take much to /forums/images/graemlins/grind.gif them of although a plasma cutter would have been nicer /forums/images/graemlins/thumb.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
also if you remove them and reweld them you can change the pinion angle to you specs /forums/images/graemlins/waytogo.gif
[ QUOTE ]
whats the trick to getting them perfectly aligned with each other though ?
[/ QUOTE ]
A magnetic angle finder. They cost $5 or so at Sears or most any good hardware store. /forums/images/graemlins/thumb.gif
or you could bolt everything together under the truck and than tack the pads where you want them and than un bolt it all to weld them all the way around, that's how i plan on dooing it
[ QUOTE ]
[/ QUOTE ]
Ditto, then you also know you get the pinion angle right where you want it.
