Since I got the truck I always had it in the back of my mind to redo the breathers on my differentials. So now comes that time!
I found some pretty cool stuff that I can use from Jegs and McMastercar. So far I have only assembled the parts. I will install it within a few days.
What I am using is 25' of 5/16th rubber hose to connect the front and rear diff together. Then I am connecting the trans and the t-case together on a sepparate line. Then I am installing a larger breather for the gas tank vent because the charcoal canister is gone and the vent is currently just sitting on the core support.
All of the lines will have a brass mesh breather on the end of the line and they will be mounted up out of splash zones.
