differential vents
GsxrMike
Tonganoxie, KS
Does anybody know where I can buy vents for my differentials. I think I might run them up into the cab anyway but I still want vents on them. While I'm at it, I don't have any inner fenders and with all of the mud she is going to see I want to put some rubber mats from the frame to the fenders to help keep the mud off of the motor. Anybody have any ideas? I have also seen boots over the distributer to help keep them dry. Anybody know where I can get something like that, or have any other ideas on how to keep the dizzy dry?
By 'vents' for the diffs, I presume you mean breathers, i.e. some way to get air in to a long hose going to the barb on the diff?
The plastic gizmos used by the factory are not available aftermarket, that I could find, nor from GM any longer ... but are easily found at the junkyard.
Alternately, I see lots of people use crankcase breathers, the little (2-3-4") air-filter looking things that you can get in a variety of colors and blinginess in the pimp-your-rice and 60's-musclecar-chrome-Mr-Gasket aisles of your local parts house.
Basically, you want something that will let air in and not let water in ... you could use a filter for an air compressor, or braze bungs into the bottom of your air cleaner, or whatever.
But a row of those crankcase breathers is just funny ... "You use 'em on your Honda, I use 'em for my rear end" :haha:
And as Dafey just said, yeah, the hose is your basic vacuum hose -- it's just air, so it needn't be fuel line or anything fancy.
Your other questions ... donno 'bout swimming caps for the dizzy.
My local hardware place carries rubber sheets in varying thicknesses, sold by the foot. IIRC they sell up to 3/8" or so thick, which would be enough to prevent a small third world country from entering your engine compartment.
I still have a piece I cut bits off now and again that I got on a junkyard tailgate as a liner; that one is fricken nuclear industrial or something, has bits of metal in it like it's made from recycled tires the way they do running tracks. :dunno:
-- A
Jus get some heater hose from auto store and then check in their "ricer" section for some lil breather filters. I used a male-male brass fitting to connect the hose with the breather, but you could just shove the hose in the breather, maybe .
As far as the boots. go get one off of a MUSTANG. they will say mustang or ford on them, but since its in the back of the motor, who cares. Thats about the only ones I know.
I personally wouldnt run them in the cab, the diff. builds up gases and that is partially why there is a vent, Id rather keep as much out of the cab as possible. I ran mine beside the brake booster, thats about as high as you can get really. If you in water any higher, Id suggest investing in SCUBA gear. LOL
To the left is the windshield washer motor. That gives you an idea of where ive got mine mounted.
For those wondering, the two black ones are front and rear diff. the red one is for tranny and the thin vacuum type hose is for the Tcase.
That little plastic vent hose plug/cap. If you can't find them in the junk yard, order from GMPARTSDIRECT. #15771000. Pack of 10. $16.30+S&H.
I saved this from an earlier post.
