differnt front and rear axle gear ratios
coleschreck
Newbie
Hamilton, MT
i just bought a 1982 k5 that has different front and rear axle gear ratios and it just sucks in 4 wheel drive. what would be the cheapest way to get the ratios the same? Im fairly skilled in my mechanical ability and just want to get this thing figured out so i can go hit up some trails.
The cheapest way is to swap the ring and pinion in one or the other so they match. But, depending on what you are going to do with it and what axles you have now, you might want to do an axle swap instead.
BTW, if the front is "faster" than the rear (lower number) then its not as bad as than the other way, because the front tires tend to pull it along.
When they are slower, it sucks because they act like an anchor.
I know some mudders who have done it on purpose. A 3.89, say in the front, and a 4.10 in the rear.
Or, sometimes they just run slightly bigger tires in the front.
The early Jeeps, and I think some Toyotas did that from the factory, and Toyota may do it still.
But not that dramatically.
It would be like 4.11 in the rear, and 4.10 in the front.
