Wish I was home now to check, but does the vent line on the sender (at least for the later rigs) have a "rollover valve" on it?
Fairly recently started having a problem with filling the truck up. Even without the vapor recovering nozzles, the pump continuously shuts off while trying to fill. If I can get it started, even on the minimum notch when present, it will still click off. Turning nozzle upside down doesn't help. Multiple stations, multiple nozzles, all act the same.
When this started happening I crawled under the truck and realized (for years) my tank wasn't vented through the vent line...I had put a bolt in there. Thinking that wasn't helping, I re-did that, plumbing a hose up the inside of the bed wall, with a filter type cap. It vents.
Only thing I can think of is if there is a valve on the sender that isn't working right. I recall seeing something like that, but can't recall if that was on my sender, or another design.
