I'd plate the frame with 1/4" steel after welding up the crack...drill a hole at each end of the crack,to avoid having it spread as its being welded..then grind the weld flush and plate over the cracked area,at least a few inches if possible..
I think you chose the right way to go--no sense in putting a rebuilt or even good used engine in it until you have a solid chassis..
I bet you'll stumble across a good used engine for a decent price if you ask around and keep your eyes open...
