blackbronco92
Registered Member
Hey guys. My '87 Pickup developed an electrical issue when I took it upnorth for hunting.
On the way up everything was fine. I took it out into a couple of trails and dirt roads and jiggled some things up, I'm sure, and I assume I've got maybe a bad ground somewhere.
The brake lights are very dim when the brake is applied. If the parking lights or headlights are on, I've got no brake lights at all. Turn signals work in the front and rear of the truck, but same rules apply. In the rear, they are dim or non-op with lights on. The hazard lights have been screwy for years, so I'm not sure if that is related or not, but when the hazard switch is pressed, they'll flash slowly and increase in speed until they are flashing extremely rapidly, but again I've had that issue for some time now.
I've checked all the fuses in the truck and I'm good there.
I pulled both rear lenses and housings out and inspected wiring... It's old but connections look good.
Can anyone give me an idea what might cause these symptoms? I'm assuming I've got a bad ground or a short, but since the headlights affect the brake light operation, I'm thinking somewhere in the front of the truck rather than the rear...
Thanks for any help provided.
Aaron
Aaron
