Disappearing H2O
bigbluesuburban
Constant State of Perpetual Anger
I am adding water every 2-3 days to my radiator. I can tell when it gets low because the heater works and the temp skyrockets when an airbubble surrounds the temp sensor.
I have no visible leaks and I don't smell burning antifreeze. The oil is not milky and everything else works great
SOOOOO... Where the heck is the water going?
check under you carpet...possible leaking heatercore.
Replaced the cap with a pressure release cap to make refilling easier. AND... replaced the overflow reservoir cap because the rubber inner grommet went missing... Water still disappearing... Dangit
Ya know, I just thought of something. I disconnected the rear heat because it intruded in the cargo area too much. I need to check all those hoses and make sure that my "bolt&hose clamp" heater hose sealing system is still functioning properly.
I was loosing water and it was coming out of the weep hole on the waterpump. No visible leaks anywhere I noticed my waterpump shaft was not tight as it wobbled when the engine was running. I replaced it and no problems
Ira
id be wiling to bet that this is your cause...
Rear heat, WOW! I've only seen one of those in print.:D
