lazuras_dc
Registered Member
I'm sure this topic has been beat to death, but as far as searching previous threads what I've come up with is that if I wanted to do a disc conversion on a 14bff , I would need 76-78 eldorado calipers. However, I also read that if you buy a loaded caliper from NAPA or carquest or something they would not come with levers/springs. How do you overcome this? Does the current connection for the e-brake on the drum brakes attach directly onto the calipers without any mods?
This is what I found at NAPA - https://www.napaonline.com/Catalog/...667_0248558177&An=599001+101978+50010+2010008
What does something like this run if anyone has previous experience?
Also is an adjustable proportioning valve needed? If you don't get it, do the rear brakes lock up significantly before the front or anything like that?
Thanks!
Thanks!
