Disc brake conversion parking brakes
SpeedlabDan
Keepin it trashy never classy
Woodstown, New Jersey
Ok I'm researching parking brakes for my d70 drw that I'm converting to disc using Kurt's kit.
Being the same type setup as the more popular 14bff setup, what are yall runnin for the parking brake? Driveline cut brake? Pinion brake? Brand/manufacturer?
I've heard the possibility of a Cadillac caliper but I know nothing about that.
I'd like to keep it mechanical to work with the factory square body foot pedal.
FWIW , I have the Cadillac calipers on my 12 bolt. They don't hold well, I can easily drive through them, just barely hold at idle. I compare it to drums which can hold lots more. I know that even the little drum brake inside the rotor can't handle as much as the old huge drum brakes, but I feel that they are still better than the Cadillac calipers. Maybe I just have to make some linkage to increase the pull on the cables.
I had the drum in rotor parking brakes on my 02 Silverado 1500 and they were completely useless even when adjusted so the drag. There's gotta be something better
I’ve often wondered why no one has tried using the rotor vents as a parking pawl. Can someone explain why this wouldn’t work or why it’s a bad idea. :dunno:
Maybe for sisk of distortion to the rotor or damage? It is an interesting concept though
people call it a parking brake . but back in the day it was a EMERGENCY brake for oh crap . . . . it was also used as a parking brake .
the claw in the vent holes would snap stuff off and also you would need to roll the other way to get it to come out possibly .
and if you still want caddy calipers here ya go . new product from ruff stuff vendor here . https://www.ruffstuffspecialties.com/catalog/R2262-A.html
dont forget high angle driveline t-case parking brake kit . http://www.highangledriveline.com/e_brake.html
I’ve got the Cadillac calipers (TSM copies) and they work just ok. I can drive through them by accident sometimes, but I think the cable needs adjustment.
I realize that it serves a dual purpose but this is just for a parking brake. Never thought about it sticking though.
I like the hi angle kit but it's pricey. I'm calling it a parking brake for my purpose of parking while towing I'd not like to rely just on the trans pawl.
Another issue I see with the drive line cut brake would be having an open rear ion gravel etc the traction would need to be even across the axle correct? I know it's probably unlikely but definitely possible in extreme case
If the Cadillac caliper is properly adjusted off the rear axle in a vise, makes it easier to do. You also have to set the parking brake every time you use your vehicle to keep proper pad adjustment. Mine hold very well and i have the smaller version 79-85.
Ive got tsm calipers on my 97.
I find once the ebrake is applied, pump the pedal a couple times and it holds just fine.
If I didn’t use truck to launch boats, I’d have not bothered wasting my time and money on the eldo Caliper swap. Would have just left the 10 bolt calipers on and called it a day.
I have the larger caddy caliper brakes on my 14bff and they hold just fine. No problems with them. I think a lot of the problems with the caddy caliper is the adjustment. Once you have it dialed in, it holds like it's supposed to.
I've also read where some have spent a long time making adjustments and still can't get them to hold very good so your mileage may vary. :dunno:
I stumbled across this as well, they say to use the e brake every now and than. I try and use it a couple times a month, seems to be working fine after 1.5 years on the road.
I bought a locking drifting lever/brake assembly off of eBay but since it requires 2 hands to actuate and lock I think it'll be a pita. I'm not thinking about a Jamar mechanical line lock.
I'm going to add a line lock to my blazer. It's an auto so not too concerned for normal use. Just want it for when I need it to hold on a hill off road or something. Driveline brakes are nice since they multiply the brake force by the gear ratio like on a Rockwell axle.
I am just starting the build on my 71 K5. I was thinking about a small disc like on a UTC for example drilled and mounted to the back of my 205 on the tail shaft. Then a separate pedal or lever in the cab to a line like. Using a small master cylinder like off the UTC or motorcycle. I don't think it needs to be very big to have the capacity to compress the caliper. So a line lock on a separate circuit.
Has anybody gone this route?
There are kits available to do this with a mechanical caliper. Then you don't have to mess with the hydraulic stuff, and it won't possibly bleed off, or lose grip due to thermal expansion. (cooling off)
I can't remember who has them right now, I have never used on, just removed one and sold it.
I think a pinion mounted disc is better,then if you happen to lose the driveshaft,you'll still have an E-brake..
I'm not sure if a pinion brake would pass here for an E-brake..
Here,line locks aren't considered "legal" for on road use as an E-brake,as they can fail if a line pops or the master cylinder develops an issue,also they will not hold pressure for all that long,they bleed down eventually and will let the vehicle roll..
