disc brakes for a d70 dually rear??
supersize75k5
OrganDonorRacing.com
gilbert az
Im looking around and reading and it aprears the dually rear has no brake kits,
so..
could I put standard 14 bolt hubs on this and use a 14 bolt kit?
and why wont kerts or others single rear wheel kits work on a dual wheel 70?
I would just look , but my 70 is still 2 hours away:D
It's the dual wheel that causes problems. If your not going to run dual wheels, Then our d70 kit should work. Haven't set it up but I see no reason it shouldn't.
There may also be a chance we could set up something a bit more custom.
I just picked up a Dually D70 with the 14bolt hubs and it came with Kurts D70 brake brackets, just need some time to get back in the garage to work on it. I would like to see some pics of this setup!
I have the 3/4ton front rotors, need to find a set of calipers.
(this is the axle BlueBlazer62 started, sold to Emmet, then I picked it up...)
http://coloradok5.com/forums/showthread.php?p=1946677
In the mid-90's I disc'd an Eaton in my C30 carhauler. I had a friend turn some 3" spacers to move my rotors inboard far enough to clear the duallie rims and bolted some 3/4 ton 4x4 front backing plates to the axle. My dad disc'd a 70hd by bolting some Dodge? front dual wheel spacers to move the wheels outboard. His truckbed is more than a foot wider than mine, tho.
Kert, please look into this seriously. I think there are enough of us here on CK5 that want to do this to D70HDs, that it would be profitable. The one stumbling block is that most/all of us are looking for a larger caliper/disc pad than the 3/4 ton caliper.
Thanks, Jimbo
Thanks, Jimbo
for off road use i cant see why you would need bigger brakes, are all newer chevy dually rears only drum? assume so:confused:
Just knee jerk reaction, please review for feasibility but could an adapter be machined that would allow you to use the caliper mount, calipers & rotors of a D60 front? Something that bolts to the backing plate mount and then to the caliper mount with the appropriate spacing and what not.
I dont know how plentiful the caliper mounts are though. :dunno:
Stock h1's, hmmmm. I'll see what I can come up with.
Read on...
http://coloradok5.com/forums/showthread.php?t=197410
:wink1:
I always come up with great ideas after somebody else already invented it. It's really frustrating...
