Disc conversion hoses
aceroth
NorCal
I am converting my 14bff to discs with diy4x brackets and 3/4 ton calipers and rotors from summit. Any one have a suggested source for hoses/banjo bolt connections? Do I just buy 3/4 ton front hoses? I don't see how those would mate up to my axle lines though. I have watched a bunch of disc conversion videos, some of which were real good but none covered this part.
Also, if you don’t have the calipers already, change to some 1/2 ton ones. The piston is smaller and better for the conversion.
Also, keep everything in case you want to switch back to drum.
Thanks guys. I see how the ORD kit works and I wanted to redo the hardlines anyway. Just ordered it.
I'm running 3/4 calipers on mine. Is there a specific year on the 1/2 tons? The ones I just searched on O'Reilly for both 1/2 and 3/4 had a 2.95" piston.
I think I just went off an '83 for all my stuff to keep it the same as my model year. Ive got 3/4 ton front and 1/2 ton rear but my rear was still way over braking. I had to add a disc/disc prop valve and a manually adjustable one and I almost turn the rear all the way off to get it to not spin circles on wet or icy roads. I am running a big bore P30 4 wheel disc master cylinder though.
There's more to it than just 1/2 ton vs. 3/4 ton.
The earlier (70's-ish) calipers are the same between 1/2 and 3/4 ton with the smaller piston. Sometime in the 80's they started offering a bigger caliper with some GVW packages on 3/4 tons, if you use a mid 80's K20 for application you'll see both options. As mentioned, the bigger pistons is sometimes less desirable because it can make the rear brakes lock up easier (depending on what front brakes the truck has, the weight bias front/back, how soft the springs are, etc.).
