Disc conversion questions
plyr2k
Anchorage, Ak
Just wondering what everybody used for hoses? I know its a 10mm banjo on the caliper, but is it 3/8s at the block? Or 1/4? Also, i have to push my brake pedal fairly far now to get it to stop. The rear brakes are into the rivets in the drums. I have my rotors calipers and brackets for the back, so i was thinking maybe it would get better after the swap? The pedal isnt hard to push. I have a 90k5 with a dana 60 and a 14bff. I also just put in a reman master cylinder, so if going to 3/4 ton is the fix, ill just deal with it. Thanks guys.
