discs for a 14 bolt FF
bajaviking
Baja
Will the brackets, discs and calibers from a 1999 14 bolt FF bolt into a 14 bolt FF with drums without any problems. Does any year mix and match?
IIRC, no they won't. The bracket spacing from the WMS to the axle mounting flange is different between the two generations.
the way i went on mine was the brackets from diy4x ($65) then just bought the calipers and pads, ended up costing me only $150 total to convert it to disc
