1967k10
Anyone know how to put disc's on a Van width 14bolt ot Eaton? Need to know to get a project finished up. Just add more spacers
or is there a better way?
or is there a better way?1967k10 said:Anyone know how to put disc's on a Van width 14bolt ot Eaton? Need to know to get a project finished up. Just add more spacersor is there a better way?
.1967k10 said:I haven't tryed it yet but I have another Eaton sitting right nest to it with disc's and the Van one had a bit more distance from the mounting face to the actual hub.
sandawgk5 said:That is because eatons and 14FF are not the same. The brakes on a van 14FF are the same as a regular SRW 14FF so the disc brake kits are the same.
Dik
nvrenuf said:Maybe I missed something... are you working on an old Eaton axle or a 73+ van width 14 bolt? I know there are some common parts between these two axles they are still different animals so you really can't use one to judge disc kits for the other.
Like sandawgk5 said, van width 14 bolt brakes are the same as a regular SRW 14 bolt.
