So here we go, a new post for talking about this.
Um... that's what I said... Your logic is the same as mine.
It will take "X" amount of fuel to support "Y" horsepower, regardless of displacement. Yeah, I know you could probably make an engine much smaller than 2.0L hit those numbers if you could spin it fast enough.
And durability was never part of my question. I know the 2.0L won't survive long under those conditions... It was about comparing the differences in design between a 6.2/6.5 and 6BT. I understand what's being said regarding more fuel=more power in a diesel, but that holds true for gas motors too.
Now, having said that... How would a 6BT compare if it were just a 6B--with no turbo? In N/A form, would the power levels be more comparable with the 6.2L V8?
I may need to start another thread... this is veering off the main topic of the thread...![]()
Yes, an NA 5.9 Cummins will be roughly the same power-wise as a NA 6.2 or 6.5. Actually, the 6.x motors have a bit better volumetric efficiency in NA form since they have more valve area in the form of 2 extra cylinders, so they should be able to burn a tad more fuel.
In terms of efficiency and mileage, the direct injected Cummins should be a bit more efficient than the indirectly-injected 6.x, but there are a lot of variables at work. How the engine is set up, especially regarding timing, makes a big difference.
For the friends of iceman getting really low MPG numbers in their Cummins, how are they managing to do so badly?
Whew....its a good thing they never made a N/A cummins B series then isn't it![]()
I will start with an off topic comment just to show you why I like I6:
I have a 12 litre CAT in my big rig, it has 1650 lbs of tq and 430 hp, the truck weighs 17000 lbs and I get about 13 MPG, when I hook up my empty trailer to it 17000 lbs for a total of 34000 lbs I get about 8-9 MPG.
Loaded to my max, 80000lbs, I get 7.5 MPG.
My friends are getting those MPG numbers from their 5.9l cummins pulling the 10000 lbs trailers.
Since I found that out I ditched my pickups and use my rig to pull any trailer I have.
I only kept my suburban and blazer chalet.![]()
and put 13 or 18 gears behind it--bet you'd be amazed at the fuel mileage towing.I thought Cummins had some NA 4B's in the early years...?
they are probably being honest. since many people i know lie about MPG.
OH displays are prooven time and time to be inaccurate.
im WELL aware of that. apparently many of the people i know are either unaware, or outright liars.
Info on the TDR says 1989 is the first year.I'm not sure about 4's. theres a guy here with a 1984 6B he put in a chevy , has a turbo. thats the inaugural year for the B.
