Nike
Mudzer - Have you completed your rear disk brake project yet? Did, or are, you going to use the small GM caliper with the TSM mounting bracket? I also wondered what TSM meant in their catalog when they said a modified GM truck rotor was to be used with the small GM caliper.
Are they grinding the 1 1/4 " rotor to 1"?? I called them and they are closed for vac. Nike in Mo.
Blue
Blue
