Oilbrnr
With 177k on the clock, I figured some of the slight roughness at idle was due to a worn dizzy, so while I was at NAPA one day, I picked up a reman. Put it in, with a new cap and rotor, and it ran like crap. Figured there was something wrong with it, and noticing that it had more end shaft play did than the OEM, I decided to put the original back in. Still ran like crap. At this point I started to pay closer attention to what I was doing:
I used a compression gauge and bumped the starter until I was on TDC compression. Chalked the degree indicator and notch on harmonic. Rotor was pointing to where the number one wire was, which is the second tower clockwise from the coil wires.
Start it up, set timing at 8* BTDC (which I'm assuming is to the right or passenger side of zero on the scale) with the vacuum advance disconnected (and port plugged).
And it runs like crap! Not much power, then as it warms up, backfires through the carb. Double then triple check firing order. Changed coil. Still the same.
In desperation last night, I really advanced it (turning counter clockwise) and the power came back and no more backfire, however, the mark on the harmonic is almost at 12 o'clock (via a Sun inductive strobe), meaning way left of the indicator. I checked the rubber on the balancer and there are no cracks or other indications of slippage.
This is a crate Goodwrench 350 with under 30k on it.
What gives?
What gives?
Your balancer was showing 0* when on #1 TDC?
