Distance from front diff to end of trans
jtrapani
Tempe Arizona
Whats that distance? From the front axle to the end of the transfer case? Which trans/transfer case combo uses the shortest drive shaft?
I Have a dodge frame w/5.9 cummins, man trans, 4x4 and a 74 blazer tub. Why not put it on that frame? just need to know if I'll have enough room for the drive shaft length. The length from the front axle to the u-joint on the dodge is approx 70 inch.
