Pretty sure that was an Accel super coil that gave me grief for the past several years, ended up being the connector portion we believe on the coil that was losing connections with the main plug to the dizzy.
$25-35 factory priced part, cost me a few years without the truck and several hundred dollars in recovery, trailer rental, fuel costs and whatnot to get it from St. Louis back to NE Fort Wayne,IN. where it sat for almost 3 years.
After several attempts at tracing bad parts, wires, had the engine harness removed 3 times to try to find bad wires, brand new distributor after 3 module replacements, nothing could be found.
Dad finally got around to messing with it, found the jittery plug one day, replaced the wire/connector piece as well as that coil with a factory unit, been running ever since, no stutters, stalls, nothing.
And the more I thought about it after he found the problem, all of the stuttering and the now and then "quick stalls" started happening after that Accell coil was installed.
I didn't want to accept the fact that a fancy, supposedly higher output coil could be the problem.
