Distributor end play
JOES89K5
Hello Members what is the endplay up & down movement on distributor shaft on a 1989 5.7 TBI motor. I’m all ready to re- install it just need to make sure its correct beforehand.
up and down means nothing.. they all have it.. side to side = very bad...
Hello My distributor has .021 end play with original thrust washer/shim.
Hello No side movement just the small end play. Just not sure what it should be it acceptable.
