The bottom pic does appear that there is severe wear going on. Does this engine have a high volume or high pressure oil pump? Either is known for causing that kind of wear on the distributor gear. The other thing that will cause it is if you are running a cam that is steel billet and the gear on the cam is steel billet as well instead of sintered iron. The last thing that can cause wear like that is if the distributor isn't shimmed properly if the block deck, heads or intake manifold have been machined and the distributor is sitting too deep causing the gear to mesh in the wrong location with the cam gear.
Revisiting this question:
My distributor still has the same issue. If my cam gear is steel, What is the best distributor gear to run? I have it out of the car now, so I could change it if need be. I am just running a OEM replacement distributor. My motor has a full roller cam set-up in it. Does that make a difference on the type of distributor gear?
thanks,
I ran into same problem. Got rid of high volume oil pump and switched to Comp Cams composite dist. drive gear. http://www.jegs.com/i/Comp-Cams/249/12140/10002/-1?parentProductId=754028 Spendy but has been run lots of miles and still looks new.
What camshaft is in the motor?
Typically the only thing that requires a bronze gear is a solid or billet roller in a Chevy.
A standard hydraulic will use a regular cast iron gear.
A hydraulic roller will need a cast gear that has a melonized hardened coating.
I agree that it is always best to check with the cam manufacturer to find out what they recommend.
Scott is right too; a high volume or hi pressure oil pump can tear up a gear too.
-Phil
Wow, that is an expensive gear. What advantage does it have over Bronze?
Thanks for the help.
Scott, does endplay of the distributor gear cause any issues like this?
I know gear shims are sold to set the endplay of the gear, just wasn't sure if that was a factor in wear.
Thanks Phil,
I spoke with Herbert cams and they said bronze is OK or go melonized if I want more wear resistance.
Which distributor do you recomend as a good stock replacement? If your distributors have the melonized gear, then I might as well just buy the whole thing if the price is decent. This is just going in a mildly build 383cid w/ a full roller cam set-up.
Are you still using the factory fuel injection on the 91 Suburban? Give me a few details about what you have and I'd be more than happy to recommend a good fit...
