simplysigns
I just got my big block in my 78 Blazer and I have a problem.
1. Hooked up all distributor, ignition and starter wires where they go.
2. Engine cranks over but no start.
3. Found the problem. The small wire to the distributor only has 4 volts to it.
4. So just to make sure. I unhooked the small wire and hooked up a jumper wire to the battery. So I get a full 12 volts. Big block starts and run great.
5. Question.... Why do I only have 4 volts? And does the distributor need a full 12 volts?
All wires seem to be fine and some are new.
