i noticed the other day that my dist was leaking and i pulled it out to put a rubber o-ring and fix the problem, then i found out it was four teeth off and all the plug wires were wrong and found another leak from a bracket bolt. so i put everything back together the way its supposed to be but it still leaks.
is a rubber ring acceptable or should i get the felpro gasket and do i use RTV?
thanks again
obijuan
thanks again
obijuan
The correct gasket shoud only cost a buck or so at the parts store.
