Ok I have been chasing a small oil leak for a while now. Is the distributor a common place to leak oil? It to me appears as if the oil comes out the base of the distributor gasket and then speads down the back side of the motor which makes it really difficult to track down since once it hits the back of the motor it goes everywhere.
I have a new distributor gasket that I can replace it with but I'm wondering how hard it is to seal up. I wouldn't think there would be much pressure back there but it seems to be getting out. I do have a high pressure oil pump which probably makes things worse.
