I'd toss that filter,water wont go thru the paper and though it may look clean,it wont let enough gas flow thru it..
I ditched those OEM filters and put an in line filter on instead,I had one carb crack and another one strip its threads and I was boned...never liked that setup--if the filter plugs up,the spring lets it get pushed aside and allow dirt & crud to flow right past it too..
I would suspect water too,if you used ethanol gas,and it is sometimes hard to tell if water is in that kind of gas,because the alcohol acts as a "dry gas" in ways--the water stays in suspension instead of sinking or settling to the bottom like it did in old leaded gas--the ethanol starts to break down after 3 months and the alcohol separates,then gets to eat away at things that dont like alcohol..like hoses,foam carb floats,gaskets,etc..
Any original hoses or ones not made after the 1990's can fail from ethanol,they can turn to a gummy substance inside,or harden up and get brittle and crack or split..the hose joining the electric fuel pump to the sending unit often fails that way--it splits and the engine starves for fuel once the level of gas in the tank drops enough to expose the split to air...
I think most car fires on an older vehicle are due to the ethanol eating thru old hoses not rated for it..
I remember rebuilding a carb with an old kit I bought at a swap meet--a good "Filko" brand one,but a day or so after I drove the truck,the accelerator pump was non existant!--it didn't squirt at all...I pulled the carb back apart and found the material the "cup" used was in pieces in the bottom of the float bowl--all there was on the cup was that coil spring,and it started to scratch up the bore where it rode!...it looked like leather..
Had to buy an accelerator pump the next day (was surprised they listed them separately..that one had a neoprene rubber looking cup on it..
