Distributor rotor part numbers
wazzabie
Washington State
For a 78 K5 Blazer the GM parts manual calls for a 1977026 - rotor D433. On rock auto it shows a ACDELCO D468 or ACDELCO D448X. I'm not sure which one to use and how they are different. Thoughts?
The difference between the Rockauto parts could be the actual manufacturer, contact material, etc.
You’ll need access to superseded part number info to know which is a direct replacement to your number.
I found this info. d448x is part number 19110934 (made in Mexico)
  • 10498150 is interchangeable with 19110934 since November 1, 2005 for the U.S. market;
  • 01977026 was replaced with 10498150 on August 1, 1988 for the U.S. market;
  • 01987672 was replaced with 01977026 on August 1, 1984 for the U.S. market;
  • 01893518 was replaced with 01977026 on September 1, 1981 for the U.S. market;
  • 01891080 is interchangeable with 01893518 since June 1, 1977 for the U.S. market;
  • 01875943 was replaced with 01891080 on June 1, 1975 for the U.S. market.
