diy 4x questions
Hayden334
Registered Member
cullman AL
I recently found the diy 4x site and have a few questions can anyone help me :confused:
  • the b52 kit where you put rear springs in front what does that help
  • the shackle flip and switch kit does it do anything besides give you a 4in lift
  • longer rear shackles what do those help
  • longer front shackles what does that help
thanks for your help:D
the B52 kit helps because its a longer spring then a stock front so u get more flex...and the shackle flip gives u 4" of lift so u dont need such a big spring so its a softer ride/more flex. it also lets u put longer springs on the rear to get more flex...and longer shackles works well with longer springs so get more flex without the shackle and or spring hitting anything, its basically is a longer path for the shackle to swing
