DIY Inside Hood Lock
GNERGY
Arizona
I wanted a way to lock my hood without doing the 2 lockable hood pins thru the hood. Had them on another truck and didn't like them. I searched for the lockable cable to replace or go with the inside the cab hood release, and they don't make them anymore.
So i bought a deep 2x4 electrical box (single recept ) and welded in the corners and the knockouts. Bought a 4-11 (recept box ) flat box cover and cut it 3/8in. larger in all sides than the 2x4 box so I could bend the metal over and weld the corners so it would fit over the 2x4 box opening.
I bought a cabinet drawer lock to put in the top cover to lock it shut. I cut a notch in the back of the box so the cable could stick out. I had to file about an 1/8th. of an inch off of both sides of the pull handle so it will fit in the box. I mounted the factory hood release in the box and mounted the box to the kick panel where the hood release was screwed to. Total cost was less than $10.
Here are a couple of pics.
Tarey
Here is the box mounted to the kick panel. It works great.
Tarey
Ya I can lock my doors, but i don't want somebody getting under my hood and disabeling the alarm sirens or battery without working for it.
Tarey
You do realize that with a simple screwdriver I can open the hood without ever having access to the hood release cable. I am all for extra security, but there are always very simple ways around something like that. Still looks good, just pointing out that there is a way to easily do it without getting inside the truck.
If you look at the latch itself, you will see there is a small tab that sticks up where the cable connects. Just push that tab in the right direction and it will pop the initial lock. I have used this to open many hoods after the cable was either broken, or removed in the wrecking yard. GM's are some of the easiest to open without a cable. There are other manufacturers where you have to remove the grill and stuff, but GM made it pretty easy. And it is pretty much required, since there is a very real possibility of breaking the cable.
OK, cool, I'll check that out. There isn't really much room between my hood and core support to get a screwdriver in there. If there is I will block that area too..
Thanks for the heads up.
Tarey
It only takes a very small amount, since I have a very skinny long screwdriver, but it works. If you look at where the cable attaches, you should be able to build a small piece of steel to block it. It may not be neccessary, but it is worth the security.
I'll look at that tomorrow and come up with something.
Thanks again.
Tarey
