anyone doing it at home with an electric kitchen oven?
Also interested. Picked up a free oven and am working on the next steps.
I want to pull the burners off the top and build a box to hang the parts in. Hook up a shop vac to catch the extra powder and then move parts from the box into the oven. That way the whole setup is just the footprint of the oven. Harbor freight sells guns too, not sure if eastwood is really worth the extra.
I have seen plans online for one made out of steel studs, skinned with sheet metal, insulated with rockwool and dual oven elements with a circulating fan. It was about the size of a coat closet, enough that a bumper could hang vertically.I saw a picture of 2 ovens stacked. Cut the floor out of one and he top off of the other. Put a fabbed metal door on it. I am thinking and old propane tank on end would work.
I took the skins of two old driers and welded some bent sheetmetal supports in it to place the fire bricks.I have seen plans online for one made out of steel studs, skinned with sheet metal, insulated with rockwool and dual oven elements with a circulating fan. It was about the size of a coat closet, enough that a bumper could hang vertically.
Would you mind explaining this? I have a smoker and have found that I suck at smoking. I'd love to repurpose this thing as a powder coat ovenI did something similar except I bought a smoker
Tall enough to do shotgun barrels and wide enough to do 12" wide rims
I don't know if if I missed it, but what temperature does powdercoat have to reach to harden and is it a slow warm up to certain temp or is it a consistent temp for so many hours kind of thing?
