got the pictures all rounded up- made this at work a few weeks ago out of scrap
in 2020 and 2021 i had multiple carbs go down with as little as 50 days between use. My 2001 honda 250ex had to get stripped down twice in 2021 (twice in the same year!) and the petcock was ruined the second time. Its a pain in the butt to strip all the plastics, and break/replace all the body fasteners...Yeah, the ethanol is a major problem in small engines. But then again, it's more the combination of ethanol and sitting. I'm used to annual carb cleanings on yard equipment and such and it looks like there's sand in the bowl.
I can say that the k5 started up and ran/drove... never sat for more than 3-4 weeks, and would be started/ moved... it just hada host of other problems and was only being moved for street sweeping and to make room to move other things. It had the same tank of gas in it for well over a year, but still started and would run. My guess is that the 12-14 psi from the fuel pump is enough to pump that stuff out of the injector pod and back down the return line? that probably would help keep things mixed i guess! gravity feed bikes and small engines don't have that advantage, and a vw running 2-3 psi from a FACET pump to a carb isn't much better.It must be a carbed issue. My tank is vented to atmosphere on the K5, so it's not being open to atmosphere that is the problem I'm guessing, unless fuel volume helps.
Both my K5 (TPI) and my car (EFI) sat for a year and both start right up on the old ethanol.
Dad said the riding mower however, had a bit of a problem sitting over the winter. It being carbed, lends credence to the carbs being an issue. On that one I run the carb dry every time after mowing.
I wonder how much damage the ethanol is doing inside the throttle body and in my case fuel rails however.
