i traded my five 35s for these 5 37s and thought it was a great deal but im having some trouble.
i know alot of yall have done this with airsoft BBs. i am having trouble balancing my rear two tires and i have taken it to discount and a buddy at 4wp and he cant get them perfect but its OK up until about 60 then the console starts shaking and the top squeaks adn my tools rattle. i also dont want accelerated parts wear because of this. the tires have over 1/4 inch of runout though.
buying new tires is not an option and its my DD. SO
what i am asking is would i be better off just debeading these myself and adding several ounces of airsoft BBs myself?
i have read about putting 16oz in a tire but my tires called for 21 oz
and 19oz when i had them machine balanced. theres stick on and bead clamped on weights currently and i was thinking if i could use this as a supplement.
also i might knock off a clamp weight while wheeling so is there a "too much" in this sort of thing?
i am kinda worried about irregular wear but if theyre balanced good enough theyll round out? just wanting to save my parts without spending the dough ($100+) to get them done and possibly shaved. what do yall think i should do?
thank you... again
heres when discount did it, they didnt even try to rotate the tire on the rim. it helped a little.
buying new tires is not an option and its my DD. SOwhat i am asking is would i be better off just debeading these myself and adding several ounces of airsoft BBs myself?
and 19oz when i had them machine balanced. theres stick on and bead clamped on weights currently and i was thinking if i could use this as a supplement. also i might knock off a clamp weight while wheeling so is there a "too much" in this sort of thing?
thank you... againheres when discount did it, they didnt even try to rotate the tire on the rim. it helped a little.
