blazin_blazer
i just ordered these disk brake brackets from kert
, and have a quick question, when i get this in and do the conversion, when i go to my parts store for the rotors and calipers... any paticular rotor or caliper, better than the others? also,what lug studs should i get to press thru the rotor and hub?
i asked kert everything i could think of, and got part #'s for the brakelines
, he also told me the stock studs will work, but he said some people get a longer stud for more thread engagement/strength. so, for the people who have done this disk brake conversion...what studs did you use?
what size/diameter are the stock studs, as i may order some high tensil strenth studs from summit or jegs...thanks ahead of time for sharing your knowledge!
