DIY4X Comp Poly Motor Mounts
I love these mounts on my truck. I don't notice any extra vibrations. If you wheel at all, something better than factory mounts are a must. Wonder why your fan is always hitting the shroud even after "adjusting" it? Or why your engine looks crooked? Lol
Just sayin'
I'll take them if you can wait until thursday for paymant
I don't see a problem with that but I do reserve the right to sell before then if someone else can pay sooner. Really don't believe in holding stuff for payment. Do you have any amount you can deposit, even if its just $10 so I know you are serious?
Just sayin'
They are definitely top notch mounts. I am getting the same ones again but with the engine side raised 1.25" so my 5.3L oil pan isn't sitting on the ORD high clearance engine crossmember that I have installed. I bought the small block crossmember back when I was going to keep the factory 400 SBC. Didn't think this was going to be a problem when I decided to go 5.3L but turns out ORD recommends the big block engine crossmember (which sits 3/4" lower) for the LS engines. Even with the big block crossmember you only have max 1/4" clearance between oil pan and crossmember and I am not really comfortable with that plus custom raised motor mounts are still a good bit cheaper than a new ORD crossmember. I am already running a 1" body lift so I don't think raising the drivetrain 1.25" is going to hurt me any.
