DIY4x Dash- Gauges, Fuses, Stereo (MD)
stumpjump
Glen Burnie, MD
DIY4x Dash-- First $550 takes it home, Located in Glen Burnie, MD
Autometer Gauges
- Tach
- Oil
- Volt
- Water
- Vac
North east autowire 20 circuit universal wiring harness
Pioneer waterproof head unit and speakers
Toggle switches
Can you change up the layout on this or is it set with the way you have it installed? IE: If some one wanted to add a speedometer.
looks like there is a plate screwed to the dash itself, so you could machine a different plate with the same hole pattern and include a hole for a speedo. :thumb:
Kert at diy4x can cut you a new plate to your specs for pretty cheap i acually have another plate that has provisions for a speedo that can go this the dash
