DIY4X motor mount question
handloader90
Building!
Colorado
Is this regular?
I have 4 holes for bolts on the lower part of the factory motor mount and the same for the DIY4X one.
The plate/mount part of the engine crossmember that the lower motor mount bolts to (pieces that fit between the frame rails) only have 3 holes for bolts...
I just checked under my K5 and it's the same thing.
There is not enough room left to drill another hole.
Its normal. You're only using 3 holes.
It's like that so the same mount works for both left and right sides. Less inventory for the vendor.
Looks like ya got the answers you needed. Thanks for shopping with us.
Thanks fellas.
Kinda screwed with my head at first.
I thought I might have had a 2wd crossmember something. I was spinning the motor mounts all around trying to see if the holes would line up with something.
