rufusbooth
I am considering getting the DIY4X competition motor mounts for my LQ9 conversion in my 73 Jimmy. Since I am fabricating up a custom engine cross member I figure I should get some better mounts rather than the stocker mounts.
One thing I am concerned with is I have always been told that you should keep both the motor mounts and transmission mounts (Transfer case) the same material. Given that the DIY4X mounts are poly...should I get poly mounts for the transfer case as well? and if so, where would I find poly mounts for a NP203 transfer case?
Cheers,
Rufus
Cheers,
Rufus
