DIY4X Question
BowtiePimp
Registered Member
Jersey
I got the Hydraulic ass. ram mount the one that bolts on the dif. cover and I was thinking about goin to the Razor back cover with built in ram mount I was wondering if the ram posistion is the same when mounted or will I have to redo the mounting tabs on the tie rod??
It's in the same spot, front to back but side to side is slightly different. You may have to move the tabs on the rod closer to the diff is what I'm trying to say.
