DIY4X vs. ORD
SKYs flip
I just like the 2 holes for shackle angle
if you set the ord kit up the way you want it when you first get it you shouldnt need two holes :D
I have the ORD flip and will most likely stick with it, cause its what I already have. When its time for 56s, I can flip em side to side and still use them. Thats nice. DIY's big advantage is the ability to use normal 2-plate shackles... so you aren't stuck with the factory ones (short!) or lowering ones (beefy enough for offroad?) or making your own (definitely not as simple as the 2 plate kind!).
j
I just put the sky's in my k5 the other day and it's good quality stuff. Of coarse GM's rivet holes weren't the same side to side on the frame. Some frame drilling was required to get good fit.
George
i have the ord's for the blazer. im going to try the diy's for the sub when its time to do the lift on it. want to see which ones i like better.
