xpndbl3
so i want to move my dana 60 axle forward one inch. I get that the one bolt hold that is drilled is 1" forward, but then there is 3 holes total, so the leaf spring center pin goes through the center hole?
What do the short bolts/nuts included in the kit do to relocate the spring forward?
Anyone have a pic of this thing in action before the front axle is bolted up?
yep, standard rust belt spring bolt removal procedure
your bolt is rusted to the metal sleeve inside the bushing.
