DizturbedOne
1977 GMC Jimmy, 400 cid, TH350, NP205. It is listed as 6,200 GVWR, and comes back as HD emissions, which basically means it does not require an EGR or Catalytic Converters, but requires everything else for that year.
It requires a thermostatic air cleaner. It has one in it, but no provision on the exhaust manifold for a heat tube to mount. It DOES have the provision on the cleaner, but I do not think it is the stock cleaner either, so that tells me little. It has a heat riser valve on the passenger side manifold, and AIR tubes.
I really want to get this thing mounted proper before I go in, but there is nowhere for the tube to sit on the manifold heat shield, like I normally see on most vehicles. Is it possible this truck did not have it? Can't find it in the Chilton's anywhere. If so, I would like documentation, or some source, to show my smog guy.
If it did come with one, how can I remedy this? I have been looking for a universal clamp on, or something like it, for two days to no effect. Can't buy the heatshields anywhere either. PNP isn't in my future until it's fixed, because this is my daily driver! Really up a creek here right now!
Thanks for any and all help in advance guys
Pic 1 - Air Cleaner
Pic 2 - Pass. Exh. Manifold
Pic 3 - Pass. Motor
[/IMG]
Pic 1 - Air Cleaner
Pic 3 - Pass. Motor
